After years of DC-2 I changed to a CE-2 a little while back. No particular reason, just fancied a change.
When I turn it off, I feel a little piece of me has died....
Given the choice between the two I prefer vibrato. Chorus is a bit swishy for me. You can produce a similar shimmer effect with the right reverb. So if I want that I just change my reverb settings up a bit and the blend of the vibrato in the Nova Repeater and the extra shimmer in the reverb makes a nicer sounding chorus than a chorus pedal
The chorus has to have a blend control for me so that I can make it subtle and I have found (after trying a few booteeq offerings) the MXR Analog ideal. If I am playing more rootsy music then it's a nay and I use tremolo as my only modulation effect apart from the subtly modulated delay on my Carbin Copy.
Would it help you see the light if I turned up at your place playing Richard Thompson tunes on an out of phase Strat, through a CE2 pedal.......
....plugged into a Session amp?
Re the OP, I guess liking digital chorus is a binary thing.
Or
11111000000001101010101010101010
I prefer this- the first lady of effects
http://www.imdb.com/name/nm6859108/
I said maybe.....
Definitely a chorus fan. I loved the Smiths/REM stuff in the 80s (even though they didn't always use chorus, it helps). My first one was cheap plastic Rocktek, which sounded surprisingly good, and even more surprisingly, never broke in my days of gigging. I did a lot of stuff (live and recorded) where I was the only guitar player, and we needed something to thicken up a clean sound. Delay pedals were too expensive to a poor student.
I have a CE-2, and will almost certainly get a CE-2w...
Its a quite nice effect if used sparingly.
weird wobbly chorus - yay (the EQD sea machine is awesome for useable weirdness)
If you work in a covers band of any description it's a must.
left to my own devices I use chorus for some clean fusiony chord stuff, the odd hair metal blow out and if I'm writing/recording
