Brand new, purchased from CrazyParts but didn't get round to installing. Used by Historic Makeovers, Corsa Guitars, Nik Huber and many many more.
Values are: 520k, 463k, 520k, 485k
-Solid Brass thread and shaft
-Real Bakelite Baseplate
-Right earbelonging curve of 30%
-Tolerance under 10% (Standard CTS up to 20%)
-Flat back cover for the right look (Gibson applications and similar)
-Smooth Torque 36-144gcm
Specifications:
Solid Brass Shaft and 3/8” X 32 Thread
Shaft Style: (24 Spline) Split Shaft, Fine Knurling
Shaft Diameter: 0.250” (6.35MM)
Shaft Height: 3/8” (9.52MM)
Thread Height: 3/8” (9.52MM)
Required Mounting Hole: 3/8” (9.52MM)
£25 Delivered
Thanks!
ok, that's fair enough.... so whats the difference between the Area59 pots and the other TVT CTS pots that crazyparts sell, is it just the torque specs?
