Ok then....stupid question time. I'm trying to establish my guitars grounding. (At least I think it's what I'm attempting to do!!). I'm such a guitar electronics noob that the multimeter that I bought didn't have a continuity setting on it. So.....I've got my guitar with a cable connected to the jack socket and using the ohm resistance tester section of my multimeter. I switch multimeter on in ohm setting and a number one is displayed. I touch probes together and number changes to zero. I touch metal bridge/plate with one terminal and touch the outer metallic casing of the cable that is in the jack socket. The meter readings for the three highest ohm settings all show as zero. The reading when set to 2000 ohms quickly reads 001..........When set to 200 ohms the readout goes haywire but settles between a 01.5 to 02.5 reading. Is the reading supposed to stay as 1 or reduce to (nearly) zero? Thank you.
