Wiring Help?
Looking for a bit of help with the wiring on my Explorer.
The plan is/was,
2 humbuckers
1 push-pull volume
1 tone
3 way pup selector
2-way switch.
The idea was, the 2 way switch , when flicked, ignores everything else and sends the neck humbucker straight to the output.
The rest of the set up would be a a fairly simple, both pups into the pushpull for coil split, from there, one vol, one tone, and standard selector switch.
But I can't quite figure it out, the neck pup has to go into the 2 way before it goes anywhere else, so then I'm gonna lose the ability to split?
So I'm either only going to be able to split the bridge pup, or, i can split both but lose the solo switch?
Or, I'm missing something, which one of you lovely people are going to point out?
  • SporkySporky Frets: 30209
    I reckon you can do it all provided the 2-way is dual-pole and the splits are done to ground.
