Only joking. Should be fine. Only time I had a problem was when I went from 10s to 13s and then it was simple tweak of the truss rod to correct an upward bow in the neck.
Be careful.
Get some 11s on that jag immediately!
You are both wiser than me on this so I'll get it done and report back.
Will i I need to tighten truss rod or mess with the staytrem ?
cheers for help fellas
Staying in the same tuning. I don't really want to screw up the setup so I'm staying at .10s i guess...
The staytrem will be fine mate
