Filling the fret channels can be trickier.
Some people use epoxy but I think it looks messy.
Another approach is to fill the channels with wood- which I quite like as an option as it gives you a faux-fret marker to target.
I'd be subtle here I wouldn't use maple on a rosewood fingerboard- it will look ugly.
But using ebony on a rosewood board gives you enough contrast to be able to see where to put your fingers.
Or you could remove the existing fretboard and glue a new one on.
Consider doing a half fretless- fretless above the 12th or 13th fret- it is a much more usable instrument.
Football is rubbish.
i heat the fret with a modified soldering gun, get a seam separation knife under the corner of a fret and gently walk the fret out with some flush ground cutters. I rarely get any chip out.
you can just rip them out but it's likely you will get large chips. Don't fill with filler.
fill with wood veneer for nice sharp lines... You can even choose a colour similar to the board for ghost lines, helpful to the player but less visible to the audience.
Instagram
poor thing
Instagram
Its amid 60's teisco spectrum bass which was teisco's attempt to do something "high spec"
Instagram
All I did was to file the frets flat to the board, which also levelled the board at the same time. It left nice markers, and if you wanted you could leave a slight protrusion so that whilst you can intonate and slide between notes, it has a slight tendency to sit truer to pitch, depending how you level them and what you want to achieve.
Alternatively get one of these...
Duration 9:02
that's what I did, both guitar and a bass, the metal board makes a huge difference to the sustain and playability, mine is an earlier brass alloy one, it looks like a gold board, it is a 'wonderful slippery thing' to miss-quote Guthrie (who is having a bit of a handful playing it himself (makes me feel sooo much better )...
Instagram
Instagram
