1) the focal length is only 18-55
2) the aperture doesn't go down that far (the lower the f-stop, the physically bigger the aperture).
I'd say 18-55 is a little bit of a limitation and encourage your first upgrade to be some kind of lens which can do zooming in to ~100mm. If you bought a body and lens separately, you could do this without needing to also buy the kit lens which will save a little money in the long run.
Personally I don't think you'll find the aperture range a limitation unless you start exploring specific types of photography, so I'd not worry about this quite yet.
VR = vibration reduction. Worth having for sports/action/anything moving/anything low light (like, indoors stuff).
Kits lenses these days are fine - certainly not worthless whatever you read on photography forums. They're not as good as the full-fat lenses you'd pay hundreds for, obviously, but they're certainly better than they used to be and absolutely fine to get the grips with photography as a skill.
I got a Canon 650D when the D3300 was brand new on the market - both were reviewed very well at the time and in reality they're very close in quality. I took all of the below on that 650D with the kit 18-55 lens. Hopefully they'll give you some comfort that you don't need to spend more unless you *know* you need a specific feature that you don't get at that end of the market. I preferred the Canon ergonomically so worth trying both brands just to get a feel for them in your hands, but be assured both are great.
I'm now a Fuji guy through and through, but you won't quite get into the models worth having at 300. I'd happily talk your ear of about them if you wanted to spend 500+!
Also worth bearing in mind you will need some software to get the most out of a DSLR though. If you shoot in RAW rather than JPG (which gives you all the data the camera sensor sees), you can tweak that in Lightroom or Photoshop to really maximise the potential of each shot. All of the below were processed in Lightroom. None would've taken more than 2 mins.
And even then, it just isn't the same.
The latest big Sony bridge is astonishing quality for a walk around but expensive - and still with limitations.
I understand the advantage of smaller sensor cameras, particularly for landscape where having depth of field is important (although you sacrifice the ultra wide views to some extent) but if you want the best quality for you money, interchangeable lenses are good.
Of course, the x100 is ace if you just want a fixed focal length all the time - with the big advantages that come from having a leaf shutter (sync at any speed, quiet, small). So that comes under "premium compact" I guess.
I'm going for a Sony A7S at some point. The ISO noise performance is ridiculously good on that camera.
Nah, just put the focus points in the right place rather than the same ones as is in the aps-c cameras. This means they're squished into the middle.
Lazy designers.
If you want full frame on a budget, you can get an eos 30e very cheap. Pair that with a good prime and some fuji velvia or provia and you have eye controlled auto focus that really works (seriously, put this in digital!) and the full frame benefits - just with film.
The sensor is the biggest cost though. It's why medium format digital is so expensive.
You could get a d700 or 5d cheap. Great cameras. The d700 is still thought of as one of the best thought out dslr's of all time.
- quality of lens
- handling of camera
- software (both in-camera and on laptop)
- quality of photographer
- light conditions
Full frame is moot unless all that stuff is decent, and by the time someone has got the hang of all of that they're usually not interested in budget cameras anyway. I'd take my Fuji over a heavy full frame DSLR any day of the week (unless shooting sport, which I'm not ).
One thing I found with the 1dsmk2 is all of sudden the I bet bargain 50mm 1.8 didn't cut it so I had to move up the lens scale.
Great camera tho, that and my Pentax K5ii with 50-135 2.8 da* lens have been my 2 fave cameras
If you're talking about film, though, I'd argue anything below medium format is pointless - given the huge advantages of digital for small sensors. If you go film, go large and enjoy 300mp + images for the insanity and excess they are
I want to get into portraits, weddings and events/low light. The Sony appeals @Drew_TNBD but the focusing wasn't stellar on the one I tried and the good lenses are enormous, heavy and extremely expensive compared to a 50mm 1.4 from the slr brands. So I'll probably go for a last gen ff camera.
@strumjoughlamps have you seen a d500 yet? It'll absolutely blow your mind for sports. Just positively rattles, and the auto focus is nuts.
I am still waiting for canon to bring back eye controlled auto focus - I used to use that a lot, not gimmicky at all - just worked great.
It's a shame interchangeable leaf shutter digital cameras are not around - I suspect the price would be prohibitive.
but wowsers detail is amazing..
you should see this in its native res...
I've often wondered who had one of these!
The camera, not the bird.
