For Sale: VHT(Fryette) Valvulator I V1 Line Driver Buffer and Power Supply - £100
Up for sale is VHT (Fryette) Valvulator buffer pedal. If you are looking for a professional spec buffer pedal then look no further. This is considered by many as
THE best buffer pedal out there. It can also serve as a
power unit for your other pedals, as well as a signal splitter allowing
you to take the direct signal straight to a mixing desk, or even
use two amps simultaneously! Taken from the website:
FRYETTE VALVULATOR I V1 LINE DRIVER BUFFER AND POWER SUPPLY
A powerful vacuum tube buffer/line driver and regulated DC power supply in one unit.
The
VALVULATOR I is a must-have accessory that combines two useful and
powerful features, a Vacuum Tube Buffer/Line Driver, and a Multiple
Output Regulated DC Power Supply, in a single, convenient, AC-powered
unit. The VALVULATOR I is a ruggedly built, compact pedal board and
professional/home studio tool that operates on standard AC wall current,
NO WALL WARTS, and is housed in a rugged steel chassis topped with a
sleek stainless steel vented cover.
Degradation of tonal quality is caused by three things:
1. Loss of high frequency response due to cable capacitance.
2. Loss of signal level and high frequency response due to impedance effects.
3. Signal degradation caused by the design of the circuitry in the effects device.
The
VALVULATOR I solves all three of these problems using a vacuum tube
based Buffer circuit to change your guitar signal from high impedance to
low impedance. You will be amazed at the renewed responsiveness of your
instrument as well as the effect on your playing. In addition, the
VALVULATOR I input stage utilizes the same circuitry as that found in
the input stage of most guitar amplifiers. This means you get the same
dynamic feel from your instrument as you would if you were plugged
directly into your amp!
The VALVULATOR I provides four regulated
and isolated outputs which will supply you with all of the clean
regulated power you need to insure maximum signal output and frequency
response from you pedal devices. And because the power supply outputs
are individually isolated, you never have to worry about ground loop
hum.
FEATURES:
- A Vacuum Tube Buffer/Line Driver and a Multiple Output Regulated DC Power Supply in one unit
- Eliminates degradation of tonal quality
- Changes your guitar signal from high impedance to low impedance
- Operates on standard AC wall current (no wall wart needed)
- Rugged steel chassis with a sleek stainless steel vented cover
SPECIFICATIONS:
Input Impedance: 1 megohm
Output Impedance: 600 ohm
Gain: Unity Gain at -20dB Nominal
Tube Complement: 1 12AX7WB Sovtek (Russia Selected)'
http://i330.photobucket.com/albums/l421/nikolas7333/Ads/NP/Valvulator/IMG_0056.jpg
http://i330.photobucket.com/albums/l421/nikolas7333/Ads/NP/Valvulator/IMG_0061.jpg
http://i330.photobucket.com/albums/l421/nikolas7333/Ads/NP/Valvulator/IMG_0062.jpg
http://i330.photobucket.com/albums/l421/nikolas7333/Ads/NP/Valvulator/IMG_0063.jpg
I'm
based in SW London. Local collection is preferred to avoid the risk of
damage, however I'm happy to post. The item will be securely and safely
packaged.
