I wonder why Andy didn't go with the Crunchbox to begin with? Do you think JHS got their foot in the door first and maybe gave him a pedal to try, he liked it and so it began....
Compared to my EHX Soul Food which I was using to get the classic rock tones, it has a lot more bite and top end, just like a Marshall would. Also, the crunch I get with the Soul Food's drive at around 2 o'clock, I can get with the SL Drive at 9 o'clock! The thing has tons of gain, but as you turn the gain up past about half way, the sound starts to really thicken up, which is great for leads.
Compared to my amp's lead channel, the drive from the SF cuts through on the low mids, whereas the amp's natural drive tone has a higher resonant peak. The other difference is that the SL, with the drive turned up, has a very spongy attack compared to the lightning quick attack of the amp's lead channel.
One surprising discovery is how great it sounds boosted with my Soul Food. With the drive on the SL set up for a classic rock crunch (around 9 o'clock), I can boost it with the SF infront set with level at around 2 o'clock and drive around 9 o'clock, to get a really authentic and aggressive 80's metal tone.
I've also tried all the different microswitch positions, and settled on the superlead mode with high/mid cut. The default superlead mode sounds a bit too bright and in-your-face for me, and while I like the superbass mode on its own, the bottom end flubs out once I boost it with the SF.
All in all this pedal is definitely an upgrade to what I was using before and not only is my base tone improved, it has opened up more options for boosting and creating new tones. In the spirit of objectivity, the only criticisms I can think of is that it has a little too much gain on tap for my needs, and unboosted, it has a bit of a mushy attack at high drive settings.
