Kmise MI0568 Dual Hot Rail Humbucker Blade Pickup 4 Wire Single Coil for Electric Guitar White https://www.amazon.co.uk/dp/B016UE1KUI/ref=cm_sw_r_cp_api_EwL6xbG473HHM
Then solder the wires matching the pickup you remove. Two will be tied off (unless your guitar has coil splits). Red will usually go to the small lug of the volume pot & green or black will go with the braided silver wire to the back of the pot. (soldering to the back of a pot needs a bit more heat than most low powered soldering irons mind you)
