Instagram
There are also some - mostly older - keys which look similar but are made from thermosetting resin rather than thermoplastic and will not soften no matter how much heat you put in, so make sure you get the right type!
I have a vast number of second hand machineheads which I keep for this purpose so I can usually find a fairly good match - if you can't get anything I'll see if I can borrow one of those tuners to match a single key to.
http://www.allparts.uk.com/products/plastic-buttons-for-gluing-or-melting-onto-vintage-style-keys-oval
Edit: but currently have no stock. They will order them for you though
They do look pretty similar to the Gibson ones too.
