http://www.rothkoandfrost.com/custom-waterslide-decals-uk-for-guitars-bikes/
I have issues with the decal coming loose when doing this.
I have done a few black and colour decals at home, but they never match the quality of the ones I have had made for me
Instagram
http://www.thefretboard.co.uk/discussion/61134/sarge/p1
obviously it needs to be something really thin and really clear to work well with a waterslide decal, and it needs to work well under paint whilst not containg solvents which might melt the decal. And the metallic paint you use also needs to be thin, but give really good coverage if you don;t want a bumpy logo
I am okay with this method for a good DIY job, but it won't give the same result as a professionally printed logo and by the time you have purchased the right paper, paint and glue a professionally printed logo doesn't seem so expensive.
I have had loads from plankspanker which have been excellent, but rothko and frost are doing me repro logo for something unusal at the moment.
Instagram
I did the gold DIY thing once, printed in reverse. Infill with gold; thin lacquer coat to seal. Float off and stick to a fresh bit of decal paper, clearcoat that side. They stuck down fine, I made a load since you're printing an A4 anyway, and picked the best ones, flattest and best coverage to flip & recoat etc.
Used a gold paint pen which goes on thin but tends to sort of well up where you stop & lift off the decal, could maybe draw that up with a small brush but I just did a batch to be able to choose the good ones.
The gold R&K do is bright gold vs the flatter sort of gold possible with paint. And it's quite a faff but Ok if it has to be that tone of gold.
Tried it with silver but it showed faintly through the black when flipped, so went R&K that time. It's also less faff, if you can make the graphics at least.
Looks flat/matt here but it is gold, just my shit photo skills
http://www.alleykat.co.uk/images/stuff/misc/zen3.jpg
