* Driver tae engineer*
"Nehesay look out, ,there's a fuckin' camel on the track"
Straw man my comment if you like, or you could look at his back catalogue of anti-trolling and come back to me?
Manchester based original indie band Random White:
https://www.facebook.com/RandomWhite
https://twitter.com/randomwhite1
That's cool and like I've admitted since ground zero here-I'm no scientist, I concentrate on important shit like being good looking and on fleek with my fashion etc (which I'm awesome at btw).
What I was trying to say to you
was judge a video on its entirety rather than 30% of it, I'm sure if you watched the rest you can pull apart all his science and reasoning but all your posts seem to concentrate on the bending of steel tube yet you don't pull apart anything else-that to me tells me you've either not watched the rest of it (very likely) or that's the only thing in the video that you can criticise (less likely).
im not here to pick fights or prove anything.
ive enough shit going on trying to disprove allah in the other thread...
And this is assuming a perfect vacuum inside the tube, which isn't what Hyperloop are planning - they're looking at about half atmospheric pressure. An astounding 500g per square centimetre. Woo. A human hand has a surface area of about 0.054m2, so your hand (which isn't anything like as strong as steel) is under 540kgf.
See? Bunkum.
The real proof that it's nonsense? Half an atmosphere is pretty close to the pressure differential that an airliner at 30,000 feet is under, and they're generally made of aluminium which isn't as strong as steel. How often do airliners explode from the air pressure differential? They're of a comparable scale too.
What a muppet.
I also have seen quite a few of his other videos, he does know what he is talking about when it comes to science.
I don't have a degree but there wasn't anything near degree level science anyway. I have just finished my physics, maths, chemistry and biology a levels and didn't see anything that was obviously dumb (apart from his haircut).
He also isn't a conspiracy theorist as far as I know and iirc he has actually made some videos disproving a few conspiracies.
The bi metallic strip thing.. A bi metallic strip is several inches, and so to get visible bending you have two materials with different heat expansion properties. But over 600km or however long it is you don't need it to be two different materials, the difference in heat if the top and the bottom (from sun and shade) will be enough that the top will have extended more than the bottom.
Although I am sure there is a solution to this, after all look at all the thousands of miles of pipes in Alaska, yes they aren't in the sun and they aren't vacuum.
Also I would say the statement "he is wrong with almost every statement he makes" isn't true.
There are a few things he exaggerated to get a better point across with the sums.
Maybe I am a bit more convinced because I watched more than 9 mins in. He does have a habit of waffling and not getting to the point quick enough.
The most compelling points he made were in regards to the depressurisation of the tunnle causing everything to fuck up basically. Much death, much cost, much sadness, all from what would only need a bullet at any point across the 600km stretch if the tube.
Edit:
For all I know you could be a professor at Cambridge, I'm not saying you don't know your science at all. Just saying he isn't as bad as your are making out, imo at least
They are in the sun, and they're under a greater temperature and pressure differential. It's also more important that they're airtight.
Why would depressurisation cause such a disaster? The answer is, of course, that it wouldn't. At full atmospheric pressure it'll just increase friction and slow the trains down. This isn't a submarine under 30 atmospheres - it's half an atmosphere. Not enough for explosive recompression with any size of hole.
A catalogue of anti-trolling doesn't mean anything if all you're doing is grabbing facts and running away with them. Technologically it doesn't seem any more complicated than a MagLev train in a oil pipeline. I'm not saying that is insurmountable, but it's certainly within possibility.
I like the bit where he tried to say it was a ridiculous amount of steel, because it was the same amount of steel as in one of the original World Trade Center towers. Well they built those, so how is that ridiculous?
This is why it is so hard to weld aluminium as it is even more conductive and the heat quickly dissipates into the rest of the structure.
Also there are plenty of steel tubes above ground all over the world, carrying some very flammable materials.
And like bridges these tubes will have growth already calculated into the design.
This really is not a big engineering challenge.
The big challenge is to find a route where they can build this thing Ina straight line.
Personally I would have gone with a sty stem of smaller pods that hold say 20 people at a time rather that long trains, this would make it possible to introduce bends.
Still pretty pointless discussing the theory, I'll wait for the first proper working one, that will answer all the questions.
if it works I definitely want a go!
Dubai to Abu Dhabi is not a 4 hour flight.
The Shanghai Maglev has already been invented and does a similar job (and I've ridden a good few times).
Yeah maglev exists, but this is in a vacuum tube which makes it more awesome ;-)
They do claim it will be significantly faster too, but haven't actually got a full working prototype yet.
They are expert at making long light weight pressurised tubes.
Personally I think the tube should be transparent so you can see the world go by.
See also more modern research (still too early to use for this sort of application, mind):
https://www.caltech.edu/news/caltech-scientists-use-high-pressure-alchemy-create-nonexpanding-metals-1544
Id prefer to travel like this actually![:) :)](/plugins/EmojiExtender/emoji/fb/1.gif)
So lots of shock waves to deal witj
