FS: Hughes & Kettner 18w valve head in vgc.
£260..
Will sell for 240!! cash or PayPal.
Awesome, versatile, well built and portable 2 channel valve head with output switchable between 18, 5, 1 and 0 Watts (for silent recording.) Great for home use and gigs! Has an effects loop and can power 8ohm or 16ohm cabs.
The valves are very easy to swap as the amp is self biasing. I changed the valves to better match my personal preference, but have put the original set back in. Hence the stock valves have had very little use. And the amp has only been used at home and stored in its soft case (included) so is in very, very good condition.
The cleans are very nice, not quite Fendery, a bit more modern sounding I'd say, and the lead channel can go all the way up to some pretty serious high-gain stuff! Or crunch tings in between, obviously. Also has blue LEDs that light up when amp is on so it looks very cool in subdued lighting!
Collection from Brighton preferred, but willing to post. You're welcome to come and try it out if you're local.
More specs :
Clean and Lead channels, both with GAIN and MASTER controls
2 x 12AX7 Preamp valves, 2 x EL84 Power amp valves
Controls: Treble, Mid, Bass EQ, Lead Boost and Channel Select switches, Master and Gain controls on both channels
Power: 18 Watts
Four-step power soak
Switchable to 18, 5, 1 and 0 Watts (for silent recording) power outputs
Built-in Red Box recording output
Serial Effects loop
Dimensions: 356 x 156 x 150 mm
Weight: 5 kg
Includes padded gigbag, kettle lead and manual.
Thanks.
http://i.imgur.com/sc6pERH.jpg
http://i.imgur.com/sudbL5C.jpg
Looking for weird/lofi reverbs..
Caroline Meteore?
Keeley Hooke..
Keeley Mod Workstations.
Or anything else weird & wonderful.. Try me.
