SOLD: Peak FCB4X MIDI controller, £110 delivered
Cracking little MIDI controller here - selling 'cos I've got a bit of an issue with it. First the good:
- Sends PCs and CCs (up to 16 messages per preset)
- Full alpha-numeric display (including patch names)
- Multi-coloured preset status LEDs (you can change the colours)
- Nice and small so as to fit on an existing board
- Can take two additional expression pedals
Now the bad...it doesn't play well with others. Specifically, it can't be on the same power supply as anything in your signal chain - it pushes a sine wave back through the power supply. I haven't tried it with a proper, expensive isolated supply - I did try it with a separate single-ended PSU and it worked fine, though. I just don't want to run with three power supplies on my board (my Eventide doesn't like friends either), and I don't have enough room under the board for any of the more expensive units because I've got a relay switcher under there too.
Here it is:
It's currently on eBay for £120 plus delivery, but for you guys I'll do it for £110 delivered (a good £30 less than I paid for it second-hand).SOLD!
<space for hire>
