If you track down a used one, be aware that the switch position moved a couple years ago. It used to be behind the control knobs, now it's in a more classic upper-bout position.
Not much out there sounds just like a Les Paul - and indeed Knaggs' own SSC model is actually closer still to one than a Kenai is, but the Kenai is still an absolutely outstanding instrument that certainly nods in the general direction of the LP but does its own thing really well, and is far more comfortable to play. The neck carve is just awesome.
thanks so much for this extended description!
it sounds pretty much like what I am after then,I will be getting one in 6 weeks or so (I will be ordering tonight)
and I'll make sure that the 3 way switch is behind the controls,right where I like it,
again many thanks whitecat, really helpful!
it's now done,ordered!
it is new,I am going to try to find out about the switch position,I was told that it will take them around 6 weeks to build it so I going to see if I can get it where I want,
I will post some pics when it's here (I have to learn how though..)
thanks again whitecat,
faded onyx tier 3
