NGD 1966 Fender Mustang
bbill335bbill335 Frets: 1408
edited November 2016 in Guitar
Well, after a day of hardly putting it down, I feel I did the right thing.
The neck is really chunky, and the fretboard is wide compared to what I normally go for. It sustains like crazy, even unplugged.
The switches are a tad temperamental, I need to get more switch cleaner in there.
A lot of old mustangs I've seen in pictures have string trees way down to the headstock, no spacer. Or at least, not a spacer like this. The high E likes to jump out of its nut slot sometimes, which is a problem. I was thinking a steeper break angle over the nut would keep it in place better. Is that a good idea? I need to find a shorter screw (3/8" I think) for the tree so I can screw it down more.
It's fucking dumb but I feel like I'm Harry Potter when he picks out his wand. This guitar just sounds like me.
0reaction image LOL 11reaction image Wow! 0reaction image Wisdom
  • VoxmanVoxman Frets: 4972
    Congrats on finding a guitar that sounds such a good fit for you. I had a similar problem last month with my A string slipping off the nut on my 69 Strat.  The nut was worn down but a new nut solved the problem.
    That is too cool. I'm really chuffed you went for it and that it turned out so well :)
  • BridgehouseBridgehouse Frets: 24584
    Brilliant! Really pleased you got it - it's a corker.
    You could try a higher gauge of string (like 11's of you're not using them already) to increase tension to stop jumping around. Otherwise you could try a lower spacer to increase the break angle after the nut. The Mustang trem does give a low tension due to the break angle as well..
    The switchcraft switches do tend to fall apart after a while - and they are probably loose/corroded which will make them intermittent. A good tech will swap them out for next to nothing as they are as cheap as chips.
  • bbill335bbill335 Frets: 1408
    I've actually gone down a gauge on this one (11-48 instead of my usual 11-54) and I think some switch cleaner should fix up the old switches. Pots work perfectly and I love the big chunky knobs (the MIJ Mustangs have smaller knobs).
    Thanks for the kind words!
  • SassafrasSassafras Frets: 30358
    Nice.
    You've even got the period correct curly lead.
    I admire that sort of devotion to detail.
    Sassafras said:
    Nice.
    I inherited that lead from my grandad. It's Fender branded so I think it must've come with his mid/late 70s P bass. It's a hefty cable!
  • Lovely colour....
  • That's a beauty, they are great guitars.  I had a white 68' for a number of years, my bandmates actually called me out when I showed up at rehearsal with a Les Paul one day.  They liked the sound of the Mustang more.
  • GassageGassage Frets: 31591
    Well jealous.
    did you get it off Martin?
    Gassage said:
    Well jealous.
    Yep!
  • Very WowWorthy Indeed.
  • LoobsLoobs Frets: 3897
    Nice! Nice Traynor too.
    The Mustang + Traynor is a great surfy combination. The reverb sounds like an outboard tank, drippy, splashy and extreme.
  • blueskunkblueskunk Frets: 2934
    Very cool indeed. Well done :)
  • ICBMICBM Frets: 74482
    If you're determined and you want to keep the original parts, it's possible to dismantle the switches and clean the contacts more thoroughly than you can with squirt-in cleaner.
    The string tree does need lowering, that's the correct spacer for a G/D string one - the E/B one should be half that height. You know to check the screw length! If necessary and you can't find a screw with the right head to look correct, you could cut it down with a pair of wirecutters and re-shape the tip with a file or emery board. Yes, I am a geek and these things matter to me :).
    It is, I think, the stock spacer for the tree and Mustangs didn't ship with a tree for G/D until much later, iirc. I'll go into the shop and see if I can get a shorter screw and spacer in the week. I need to ask them to take the nut slot for the G down just a teeny bit, that E major chord is sounding a bit janky with a sharp major 3rd!
    It's certainly possible it was made like that, yes! It is too tall though, the right spacer is the one about half that height.
    @ICBM ;It's weird because so many of the old Fender necks I've seen have no spacer, just the tree screwed all the way down, like this:
    If I did that to mine, would it stop the high E from escaping the nut slot?
    Probably. Yes, most are like that - although I tend to find it's too much the other way and can cause the top strings to bind in the nut. You could try a temporary test by re-fitting the one you have with the spacer above the string tree - it will look odd but should let you know whether that will fix the string jumping problem without needing a new nut.
