Been meaning to ask for a while but kept forgetting. One of my Teles(Am Std) has this problem, when you play the open G String and even on some fretted notes. It's not majorly terrible but it's noticeable and would like to get rid.
I can touch the string behind the nut and it deadens it and sounds right, I could(and have) wrapped a velcro thingy round it and that cures it but I want to get rid of the issue without having adornments on my Guitar Headstock.
So I assume it's a badly cut nut or something and the string isn't making total contact along the slot. I've not tampered with filing nuts and wouldn't even know if there is just one size file for all slots or is there a file for each nut slot(string gauge)???????
Is it easy to do? Does the material remove easily or is it tough stuff?
Also, could the problem lie elsewhere and it not be the nut?
Thanks
Instagram
I accept it as coming with the territory of a Tele and you either put the hairband mute thing on or play on and forget it.
I've not owned that many really so I'm not aware of this stuff, I only have and have ever had the 2 that I own and my other one doesn't have this issue.
I have wrapped something round the headstock to deaden it but thought there may be a cure, filing the nut etc.
add another string tree or put more winds round the post to increase the break angle
My 52 AVRI has no string tree so I leave twice as much string, put a bunch of extra wraps (all moving towards the headstock) and problem is sorted.
Try that before you carry out any invasive surgery.
Edit: just noticed that's what everyone's already said.
I really should read these threads more thoroughly.
also, i'm okay with quick fixes to get through a gig or two, but do get the nut fixed properly at some point
Instagram
Peace.
