Hi Has anyone owned either the modern satin or modern T satin or I guess any suhr guitar with Jumbo frets?
I was wondering how you found the fret ends of the guitars. I played one today and really liked it but found the fret ends to be a little sharp which surprised me. I'm not sure if its how i play (thumb over, moving around the fretboard) but i found the fret ends to get in the way a little.
The frets are quite tall so i'm thinking if anyone has had the same experience? Maybe played other suhrs that play smoother with different frets? I know The heavy frets are not as tall at the 6105 or there medium frets. They might be the ticket.
I like the jumbos for there ease of bending!
My music:- https://soundcloud.com/hubobulous
Have you compare jumbo with heavy frets?
What do you think?
Unlike Suhr to do poor fretting but they don't have any real control over the occaisional neck shrinking a wee bit and the frets protruding a bit .
Also a Plek profile fret dressing at the factory is only good up till the point it leaves the factory.
Wood moves and shrinks and in a relatively short time a neck that is prone to this could need attention.
So it just needs a luthiers/techs attention
If it was in a shop - maybe bring it to their attention so they can rectify it before it goes out in the world
Many guitars have a re-sale value. Some you'll never want to sell.
Stockist of: Earvana & Graphtech nuts, Faber Tonepros & Gotoh hardware, Fatcat bridges. Highwood Saddles.
Expert guitar repairs and upgrades - fretwork our speciality! www.felineguitars.com. Facebook too!
if the Mahogony has shrunk how would you correct this? Treat the rosewood with lemon oil or fretdoctor then let the guitar get used to the climate?
My YouTube Channel
Remember to check out our Bank Holiday Sale 15% off New, Used and Vintage
https://reverb.com/uk/sales/bank-holiday-sale
Just like Feline said, I wouldn't buy it like that...but I would have the shop address it properly...then I'd buy it.
I gig a Suhr Modern Satin... never had a problem with fret ends. As others have said, it sounds like the neck may have shrunk a bit. Bear in mind that the air is very dry at this time of year. I'm sitting in my office today and the relative humidity is 39%... whereas it was 60-65% for a lot of last summer. Could be even drier than 39% in a shop - especially if the guitar is hung high, where the air is hotter.
Winter air can be very dry (so necks can shrink... resulting in neck sprout)... and, if it snows, the air tends to get even drier. If you want to measure this stuff, a £5 digital hygrometer from Amazon will give you an instant reading of humidity... but don't hold it in your hand - as the moisture in your hand will make it read high.
Guitar shops don't always get it right. I was in a UK shop in the summer... when humidity outside was very high... but, in their air-conditioned acoustic showroom (that had massive windows that bathed everything is strong sunlight).... they had a hygrometer reading 38% - but the hygrometer was right next to a humidifier that was pumping out water vapour (so the rest of the room must have been even drier). No surprise that they had a brand new and every expensive acoustic guitar that had two rather large cracks in the top.
