Instagram
http://www.stewmac.com/Materials_and_Supplies/Bodies_and_Necks_and_Wood/Acoustic_Guitar_Wood/StewMac_Triple-O_Acoustic_Guitar_Kit.html?pref_currency=P
But they also do a 000 -
http://www.stewmac.com/Materials_and_Supplies/Bodies_and_Necks_and_Wood/Acoustic_Guitar_Wood/Dreadnought_and_Triple-O_Guitar_Kits/StewMac_Triple-O_Acoustic_Guitar_Kit.html
They're not nearly as cheap as £200, but they're damn good.
I've also built two of the Martin kits - a dreadnought mahogany and a rosewood jumbo.
https://www.martinguitar.com/1833-shop/rosewood-guitar-kits-d-(dreadnought-herringbone)/c-24/p-211
If you scroll down the page to the bottom, you can see the other sizes and styles available.
They're more expensive, and the woods are better, but you really need to know what you're doing with those. Getting the neck angle right is a fucker, I got it completely wrong on the first one, and while I got it right on the second, I didn't get the join right, so it sounds as if I'm playing it through a sock.
Anyway, the reason I suggest these is that they contain everything you need, with the sides bent and everything the right shape (although you have to shape the neck joint correctly, and you do need a mould when you're gluing the sides down to the neck block and end piece). All you need to do is glue the stuff together, sand them to the right angle and finish them. That may not sound much, but trust me, it's waaaay more than that - it's the very definition of the difference between 'simple' and 'easy'!
Of the ones that I built, I'd recommend the StewMac one with the bolt-on neck, for the simple reason that if you're not happy with the neck angle, you just unbolt it and have another go. You can't do that with a glued-in neck, and if you get it wrong, as I did, you've got 400 quids' worth of firewood on your hands.
I'm very happy with my StewMac kit though.
Oh, and you get a DVD with the StewMac kit, whereas the Martin kit comes with a paper booklet that wouldn't be out of place with an Ikea bookcase. There's also a whole range of advice on the StewMac site.
You could do a lot worse than get yourself a copy of this, it's extremely informative and I found it invaluable.
https://wordery.com/build-your-own-acoustic-guitar-jonathan-kinkead-9780634054631?cTrk=MzQ1NTIxNjN8NTg2NjM1YzBlMzc5MDoxOjE6NTg2NjM1OTc5YTA1MDUuMjE5MjA2NTM6N2I5MjE4ZDc=
I do know that the way Martin sent their kits out I didn't pay duty at all (though that may have changed in the 8 years since I did those), but the StewMac kit definitely got caught in the system.
Either way, it's not a cheap option, I have to admit, but then the result is pretty good, too. If you're going to do the Mark Bailey course, you're probably best waiting, because whilst I've never done one myself, from what I've heard Mark will not let you leave with anything less than perfection. So probably the cheapest option is to get the book and wait with bated breath.
But if you have the cash and you can do both, go right ahead.
