removing marker pen on amp chassis?
have an old marshall that a tech modded once. ive put it back to stock and wondering what could remove the marker pen on the back panel, turps etc? any suggestions welcome!
  • octatonicoctatonic Frets: 33984
    I use tea-tree oil for this sort of thing.
  • carloscarlos Frets: 3530
    worth trying lighter fluid
  • RoxRox Frets: 2147
    Whiteboard marker.  For some reason that baffles me, if you write over it with a whiteboard marker and wipe it, the permanent marker will come off.
  • interesting tips, thanks!
  • ICBMICBM Frets: 73074
    Maplin Label Remover spray. Just be careful, it's a very powerful solvent and will take the panel lettering off as well if you use too much.
  • ecc83ecc83 Frets: 1675
    edited January 2014
    ISOPROPA or meths but as IC said, don't rub too hard on the legending!
    Ha!  Just looked it up. Whiteboard cleaner IS  ISOPROP!
    Dave.
  • MistergMisterg Frets: 353
    Meths will remove permanent marker easily. I mark out pedal boxes with permanent pen, and a wipe with meths takes it off straight away. Other solvents I've tried (acetone, IPA, white spirit, etc.) were nowhere near as effective.
  • WezVWezV Frets: 16967
    i once suggested that to someone when they used permenant marker on a whiteboard.  he spent half an hour going over the writing very carefully with the new pen.  i forgot to mention you have to wipe if off whilst its still wet
  • FX_MunkeeFX_Munkee Frets: 2491
    Because the thinners in the marker are Isopropal Alcohol. Same as whiteboard pen remover :)
    Shot through the heart, and you’re to blame, you give love a bad name. Not to mention archery tuition.
    It's bloody annoying.  I spent AGES marking out stuff on a whiteboard in permanent marker - a nice big grid, so I could use whiteboard markers to fill in information that changes.  And when I wiped it off, some of the permanent marker came off too.  :(
    Defeated the whole bloody object of being permanent...!  :D
    So if I'm really desperate for a boozy hit, I can just lick whiteboard markers?  Good to know.  ;)
    ill try a touch of meths first then. thanks
    That's how it starts... next step, hanging round street corners with a flea ridden Jack Russell begging for change.
    lol! but i'll have a nice clean chassis so all worth it
    edited January 2014
    It's already started; you're repeating yourself without knowing it... slippery slope, I tells ya.  :D
    ...and so am I.  Is the forum throwing a wobbler?
  • TTonyTTony Frets: 28006
    Tidied up for you :)
  • ok was in Tesco and grabbed some whiteboard pens for £2. lo and behold took the marker pen clean off with little fuss, awesome
    Thanks muchly.  :)
    Sounds unlikely, I know, but dead easy to use.  :)
