ALL SOLD NOW.
FYI I have these all on ebay as well.
Rockbox Brown Sugar pedal.
Fantastic heavy duty pedal, top quality as you would expect from the people who made the boiling point.
It's in excellent condition and comes boxed.
Great miab type pedal, very amplike and sounds good with the gain right down low too.
I've just bought a Carl martin plexitone for the extra features it has so don't really need this now.
Velcro on bottom, with box.
£55 posted
http://i.imgur.com/iD3CDLB.jpgMXR Custom Badass Modified Overdrive.
Excellent condition, comes boxed with no problems or issues.
Really versatile od pedal.
It's an analogue voiced digital delay.
I've had it a few years and have never had any problems with it. Cosmetically it's seen better days tbh, you can see in the photos the paintwork is chipped a little, the pics are demonstrative of the overall cosmetic condition, on a board it's not really noticeable and performs perfectly well with no issues.
So to the features:
The left hand footswitch is on/off
The right hand footswitch is tap tempo and the led blinks in time to the repeats so you have a visual cue of the current set time.
The top left knobs is repeat level
The bottom left knob is number of repeats
The two right hand knobs control the depth and speed of the modulation.
The inbuilt modulation is a tape style wobble modulation, the modulation is easily turned off by turning these to zero.
I don't use the switches as mostly I set and forget, if I recall correctly one switch controls the speed of the modulation.
the other two switches are delay subdivisions.
Works off a standard boss style power connector.
Also has velcro on the bottom.
Is called a coolvibe for some reason (no idea) but it's a chorus.
Built like a tank, extremely solid quite heavy I expect it will outlive me.
Has the usual chorus controls of
Level
Eq
Rate
Depth
Works off a standard boss supply, or a 9v battery and has velcro on the bottom.
This was a budget buy tbh but I've had it on my board for a couple of years cos it actually sounds really good. I only use chorus on the odd song and this is a nice lush warm sounding chorus.
I'm having a rejig and have replaced this with a flange so don't really need it anymore.
Bit of a no brainer at this price IMHO.
Has a small scratch on the side, works perfectly no issues. Has velcro on the bottom.
Knocked some money off these as I've already got a replacement lined up, so they need to go.
