Anyone tried the Acus acoustic amps?
Any opinions... good or bad?
Thanks
It does depend on what you want them for. The second channel on some of the cheaper ones is a bit of an afterthought if you want to use it for vocals as well as it doesn't seem to have eq on the second channel.
I ended up buying a Fishman Loudbox Mini which is fine for my needs and was significantly cheaper.
