Bandcamp
Simply cut the link wire on the bottom of the pickup from the eyelet to the cover tab as close as you can to the eyelet, and bend it back out of the way. Don't remove it entirely since it's harder to re-solder it to the cover if you want to put it back.
They're not expensive and you give yourself many more options (basically, any strat-sized pickup you want!)
R.
Eqd Speaker Cranker clone
BKP flat '52. That sounds really stratty:-
For a very short period in '52 both bridge and neck coils were wound with 42AWG plain enamel and the Flat 52 set replicates this with a brighter, tighter sounding bridge coil and an open, almost Strat-like neck tone. Utilising the slightly thinner copper plated steel baseplate introduced in late '51 and staying with a flat profile magnet design and deep drawn neck cover, the tone has a defined snap in the bass and authentic, full twang. The Flat '52 really is a very unique and versatile Tele® set capable of a vast range of clean and driven vintage tones.
It's a very versatile set.
You can get replacement scratchplates to fit really easily on ebay.
To me, it sounds like a hot strat neck pickup. The bridge has little in common with a strat sound, but is a very rock-sounding tele. Keef would probably love it.
So, as ever, I'd say give Ash at oil city a call. What he doesn't know about pickups isn't worth knowing. Honorable mentions to Mojo pickups too - I went for Oil City first and have been a loyal customer since, but some folk go the other way. I doubt one is better than the other
