I would be interested to find out your thoughts on pickup upgrades for a 2016 PRS Tremonti SE. Buying the signature model, you guessed that I would be a fan of Tremonti's tone (which is true) but I am looking for a versatile mix. I know that Alter Bridge's Myles Kennedy plays Seymour Duncan Custom Customs which by all accounts should not fit a PRS Single Cut (but do!). Myles has a fantastic tone.
Myles plays a SC245 which I believe is thicker bodied than the SE Tremonti. There's a concern that the TB-11 pickup should be used for brightening up guitars and I wonder if the thinner SE construction is naturally brighter anyway than the luxurious US made guitars that Kennedy plays? Therefore is it going to have the same effect or should I focus on another pickup? I did look at the JB or Custom but they both seem to be higher output. Having said all of this, someone on the Seymour Duncan forum thought I was barking up the wrong tree in questioning the Custom Custom but however I try the SD pickup configurator it never recommends a TB-11. So that's why I've been emailing the guys at Oil City, Creamery and Mojo for their thoughts. Comaring the cost of a new set of SD to them it seem like a no brainer to buy British.
In terms of tone, anything from Kossoff/Free, through to Van Halen, Pearl Jam/Alice In Chains when it suits me. I want that warm, rounded tone of a vintage Les Paul after a few whisky's that isn't afraid of picking a fight with James Hetfield in the bridge pickup. Maybe that means I should get two guitars but at the moment the only thing letting this great PRS down is the bridge pickup. If I am changing one then I may as well change the other. My main amp is a Blackstar HT-1RH so I can dial a suitable amount is distortion in there which makes me think I need more an overwound but classic in the bridge opposed to a pure distortion beastie...
My music:- https://soundcloud.com/hubobulous
Maybe not quite as versatile as some of the other suggestions but Mark manages plenty of variety with his.
Look at this on eBay http://www.ebay.co.uk/itm/292042355792
I doubt it would make too much difference tonally, but I have the base base tremonti se. (The one with the fixed bridge/wraparound bridge), and although the body is still skinny, the neck is a fat/wide cut, wheras the higher tremonti models with the trem have a thin/wide neck.
Wondered if the less wood on the thin/wide neck carve sounds tonally different to the wide/fat carve.
Custom would be closer to a Tremonti type tone if you want to use a Duncan. The Custom Custom would be fine in a Tremonti SE IMO, if that's what you want to use.
