FS; Boss SD-1 modded by PedalModsUK
For sale, SD-1 with mods as detailed here;
http://www.pedalmods.com/mods/boss/boss-sd1.html
It's a great mod that gives the pedal more lower mids and sustain without compromising the tight bass and upper mid boost that makes this kind of pedal so good for kicking the input of an amp. The mod also fixes the bleed through problem most SD1s have when bypassed, gives a higher max volume and more gain on tap, and changes the power situation so it can be powered by a standard 9v adapter rather than the 12v unregulated ACA adapter most old Boss pedals call for. The three clipping options are cool, the middle one is a bit like the comp-cut mode of a Fulldrive 2.
The pedal itself is gig-worn with chipped paint etc but in full working order.
Looking for £50 posted.
