Is it correct that if either pickup is rolled all the way back that the middle switch will not work? I.e. it relies on at least some signal from both pickups? Not that you'd ever want to do it, just wondering how it works.
My band, Red For Dissent
Yes - although what's happening is that the pot which is turned right down is grounding the output - and hence also the other one, when the switch is in the middle. This is why it doesn't hum - with the 'independent' wiring, the output is left floating and acts as an aerial.
That's why I don't understand the point of the 'independent' wiring either. There's no need to ever do it, because if you want to turn one pickup off, the switch does that.
The other problem is that it muddies the tone as you turn the volume down because it progressively lowers the effective pot resistance - eg with a 500K Log pot, if the volume is set to 5 the effective pot resistance is between 50K-150K depending on the exact taper… very muddy.
The only time it's necessary is on a Rickenbacker with the stereo wiring, where the 'normal' wiring would leave one output as an open circuit when the switch was open, which would cause even worse noise problems. But Rickenbackers are just weird . For everything else, use Gibson wiring.
Now to find out if this Kemper is really as shite as I first thought...
Having seen Queensryche last tour, where both Parker and Michael used them, they sound fantastic.
