Changing pickups/covers and wiring..........
BarriveeBarrivee Frets: 100
edited March 2016 in Making & Modding
Maybe not strictly making or modding but better here than elsewhere I reckon. I want to chop and change some humbuckers between guitars with different colour hardware. I'm looking to remove a set of Seth Lovers with gold covers and replace with an existing set of Lollar Imperials from another guitar with Nickel covers. I'm not much of a tinkerer so I've never really considered this before, but are the covers interchangeable (assuming dimensions are the same) - if so how do you remove and replace them - are they push fit or soldered or something else? And while I'm here, neither set are coil tapped. Am i right in saying if they were not originally wired for it they can't be subsequently wired correctly? Thanks in advance - I'm threatening to get my "used only once" soldering iron out and set to with it, so expect more posts down the line..................
  • GuitarMonkeyGuitarMonkey Frets: 1883
    Covers are soldered in place, you'll see when you remove a pickup. I usually cut through the old solder.
    If the pickups have only signal and earth connections (i.e. braided cable) then you'll have to re-cable them to split the coils. Probably not a job for a second-time solderer.
  • OilCityPickupsOilCityPickups Frets: 11139
    edited March 2016 tFB Trader
    Right, swapping pickup covers is not as simple as it first appears. Firstly they are soldered on, and you need a big, powerful soldering iron ... I use a 150w one with a half inch tip ... so that you apply a lot of heat for a VERY short time. next you will need a tool to separate the cover and the base while the solder is molten ... I use a polished stainless steel blade the solder won't stick to.
    Possible issues:
    1.You use too much heat for too long and damage the bobbins
    2. your separating tool catches a winding and you wreck a bobbin and it has to be re wound.
    3. Your covers are not the same spacing ... there are 52mm, 51.5mm, 50mm, and 49.2mm.
    Personally I would NEVER try on expensive pickups without knowing exactly what you are doing. Instead try on some cheap Chinese pickups to get your hand in.
    Oh I have a jig I built to hold the pickup down firmly while I remove the cover ... otherwise it will slide about when you try and apply the heat.
  • BarriveeBarrivee Frets: 100
    edited March 2016
    Right, I'm glad you picked this up @TheGuitarWeasel as I'm possibly looking to replace the removed Lollars with some H/B sized P90's or maybe winteriser ll.'s. I'm not looking to do it just yet but maybe I'll talk to you about a cover change and purchase "package" nearer the time !
    Happy to dude ... I always worry when the inexperienced tackle pickup covers ... a rewind costs £30 a coil ... even if not part of a 'deal' getting a cover changed professionally is cheaper than a knackered pickup.
    It's definitely a skill worth cultivating is cover removal and replacement ... but as I say, find some cheapo buckers to make your initial mistakes on. :-)
