And so it goes.
Done.
I had this problem, and it was solved by using two One Spots - one powering the pedals in the front, one for the pedals in the loop. Doesn't sound like yours is quite the same. Does it do the same with just one pedal in the loop, or a certain combination? Sounds like your best course is to systematically take pedals in and out of the chain until the hum disappears, if it does at all. Either way, it doesn't sound like it's the One Spot.
