FS: Amptweaker TightMetal Pro - reduced to £130.
Purchased from
@jonathanthomas83 just less than a week ago (13th May) and I pretty much only bought it because I have been dying to try one out for ages. However, I prefer the sounds of my other Amptweaker box of joy (FatMetal) as it is darker and more suited to my bands music style and I can't afford to keep both! (I would if I could)
If you want a two channel 5150 in pedal form, then there is none better than this. Oozing with features, it has THREE loops - for when it's off, when it's engaged and the boost function. It has an EQ section, a noise gate, and a Tight option for - you guessed it - tightening the sound. It can be used in the clean channel of your amp, or straight into the FX loop.
If you would like a reference, then Scott Hull from the mighty Pig Destroyer uses this pedal as his main drive.
In absolute fantastic condition with original box and 'instructions'. .
£138 £130 inc postage
Best metal pedals on the market.
