I'm really hoping someone can help me with this! I have a Gibson Custom Shop '57 Les Paul Goldtop VOS which I would like to be "aged", with checking to the surface but without too much overall damage. There are some examples of the sort of effect I'm looking for here:
http://s145.photobucket.com/user/glt56/library/Reliced%20Les%20Paul%20examples
There aren't many luthiers willing, or indeed able, to take on a Les Paul project with this level of expertise and precision required, but I was wondering if anyone could suggest someone who might be up to it, I'm certainly open to suggestions? I believe Clive Brown (in Ripon) is one of the best but I can't find any contact details anywhere. If someone could pm me with them I'd be grateful... thanks in advance.
Instagram
it's basically a choice between forcing the cracks to appear with temperature changes, or faking them with a sharp blade.
Instagram
it's a choice between the temperature change which can be too random, or the blade which is an art form.
Tom Murphy uses a blade and if you see them in the early stages they look terrible. you would think the only solution was a refin... But a bit more work and it starts to come together.
I have practised both, and got pretty close....but liability becomes an issue on a valuable guitar. It's a fine line (literally) between success and failure
Instagram
Also, if you want the 'greening' which is the bronze flakes in the gold reacting with sweat and oxidising, you'd need the proper stuff. I'd personally speak to @Lamf37 who might be able to help.
I do have Clive Browns contact details if you need them, he does however, have a long waiting list.
(formerly miserneil)
There is another guy who will do you the most convincing, expert fooling refinish but mentioning his name around here is like summoning Voldemort...! ;-)
Cheers matey
http://snowywhitefanclub.com/fileadmin/_processed_/csm_172_4_dae724c4b0.jpg
