Educate me on trem systems
Hi
Other than an Ibannez S series I owned and now miss my only experience with trems system  is the classic Fender 6 screw style.
I have a number of build ideas in the works and I wanted to do a sort of cut down rock machine Super Strat single humbucker good trem and just a volume may be tone but as cutdown as it gets.
I was happy enough with the Edge 2 trem and I want this to have something with some decent up and down.
Is that basically territory of Floyd Rose or are there other options that are easier to work with.
  • GassageGassage Frets: 31591
    if you wanna hear the wood in the guitar, vintage. if not, 2 point.
  • bbill335bbill335 Frets: 1408
    I love the fender offset tremolos, Jag/Jazz and the mustang. A properly set up Mustang trem will do a deep dive and return to tune if set up correctly, and you can have a bit of up pull. Much less ugly than those big floyd things, and you'd only have to route the top of the guitar.
  • Put a 100 people in a room and ask that question you will get 100 different answers ;)
    My take, for what it is worth, is that, while you can achieve excellent tuning with a well set up 6 or two point 'standard trem', nevertheless for extreme dives and pulls and not wanting to worry about setup and the standard maintenance of that set up, then a floyd is hard to beat.
    Trouble is, that SOME of the licensed ones are not so reliable and the genuine FR are stupendously expensive in comparison.
  • sweepysweepy Frets: 4268
    Wilkinson or Hipshot 2 post terms are the best option imho. If you want Floyd / Ibanez levels of whammy action without the locking faff I'd go Hipshot as the Wilkinson is very good but not quite as deranged ;)
  • ICBMICBM Frets: 74494
    Kahler.
    Easiest to fit, huge bend range, nearly as stable as a Floyd.
  • Vibrato...
