Some very interesting Vintage gear here........ (sadly not mine) Dallas rangemaster, JTM Blackflag
  • JDEJDE Frets: 1092
    There are numerous vintage spec guitars/amps/pedals/cars etc made by modern makers. These things are "collectables" for lack of a better term. Like SRV fans who own multiple vintage tubescreamers, there's a big market for RM's, particularly for those who are big early Clapton and May fans. Same with Fuzz Faces and more recently, Big Muffs. They mostly all sound great and mostly all sound slightly different in the case of treble boosters and fuzzes, hence the fun in collecting.
  • ICBMICBM Frets: 73121
    ThorpyFX said:
    the JTM Black flag needs a bit of a test for safety etc and then i might get the chance to give it a blast! both are all original.
    Apologies if I'm telling you something you already know, but DO NOT just power up the Marshall to give it a blast, if it hasn't been used for a long time. You need to not only have it safety-checked but powered up under controlled conditions with a Variac and metering/short protection. Old amps can sometimes do themselves very serious and expensive damage otherwise, and with something like that it will take a big chunk off the value - even just saving filter caps which might fail immediately is worthwhile, bearing in mind a shorted one can also blow the PT if you're unlucky.
    With one of those I would probably not only power it up slowly but run it with a signal generator and a dummy load, and increase the power up to full over a couple of hours to make sure there won't be an arc in the OT windings, which can be caused by damp.
  • ThorpyFXThorpyFX Frets: 6237
    No need to worry there, the owner has already beaten me to it. Turned it on and cranked it without any tests..... apparently. I'm still going to do all of the above though and thankyou for highlighting it, apparently it hadn't been used for 5 years.
    Safety is not a dirty word!
    Adrian Thorpe MBE | Owner of ThorpyFx Ltd | Email: thorpy@thorpyfx.com | Twitter: @ThorpyFx | Facebook: ThorpyFx Ltd | Website: www.thorpyfx.com
    There's no point in doing a slow power-up now. 5 years is not too bad actually - and it does depend on where it was stored.
    A friend on mine once bought an early JMP 50-watter that had been stored in a garage for about 25 years - I told him not to turn it on until I'd looked at it, but he couldn't resist. Luckily when a filter cap blew (literally) it didn't take out anything else… just left a lot of gunk inside.
    well, he blew two original mullard EL34's which is a real sad thing to have happened but at least it wasnt a transformer. The important thing though now is that we will be looking at the amp and making sure all the caps are correct, not dry, tolerances are good and the bias is right.
  • exocetexocet Frets: 1988
    The JTM looks like mine, I have the Bulgin mains connector as well but I am going to replace it with the IEC type sold by Tube Amp Doctor.
    I recapped mine, got the 16uF dual cap from them, it was their own branded version.
    http://i871.photobucket.com/albums/ab272/knackereddad/imagejpg1_zpsa4bcb94b.jpg
    That's a shame. If he'd have had screen resistors fitted - which this one doesn't have, but it needs - he might have avoided that. Mullards will normally take it, but it still puts a lot of stress on them. Don't use modern EL34s without fitting them.
  • rsvmarkrsvmark Frets: 1405
    Crevice is a dirty word - General Sir Anthony Cecil Hogmanay Melchett
    An official Foo liked guitarist since 2024
  • glynesglynes Frets: 131
    ThorpyFX said:
    Ill say this, Ive measured it, played it and its awesome. is it worth the money. at £600 for a vintage item id say yes probably. for £3k not a chance. anyway I've just modded my own germanium treble booster to match the hfe of the OC44 and biased it to match the same voltage..... and it sings the same. very happy now.
    Rangemaster Treble Boosters are worth a lot less if they have non-original solder joints after some wannabe boutweaker pulls the transistor for the sake of matching the hFE in his own cheap bootleg. But I'm sure you informed the owner of this unit beforehand, right?
    Ah so i am a wannabe boutweaker who makes cheap bootlegs?? many thanks.
    thats particularly accusatory and 100% incorrect. but seeing as i have the correct tools to measure the transistor in situ WITHOUT pulling it and i haven't  done any damage to the thing at all then i guess all is well.
    2reaction image LOL 0reaction image Wow! 9reaction image Wisdom
    Even in a completely unworkable state, they're worth a lot more than a poorly informed opinion.  <3
  • breadfanbreadfan Frets: 380
    @ThorpyFX Does the Rangemaster have that 'cocked wah' type sound?
    I've had a number of clones & some have had too much of it, others none at all.
    I've not tried an original.
  • SassafrasSassafras Frets: 30322
    Don't worry Thorpy,I've noticed that many of Glynes' post can be quite offensive. It's nothing personal, just something 'lost in translation'.
    they always sound thin on a clean amp but through a dirty amp this thing sings, no cocked wah sound either.
  • GassageGassage Frets: 31215
    What a grade A cunt.
    0reaction image LOL 0reaction image Wow! 8reaction image Wisdom
    As pleasant as ever ....
    I just got this message from Ebay…
    "Price lowered on: Original 1960s Dallas Rangemaster Treble Booster Fuzz Boost
    SAVE US $550.00
    You viewed this at US $5,500.00. It was just discounted to US $4,950.00."
    For a second I thought the price was now $550, and thought 'better, but still too much really'.
  • Thanks for all the kind comments, any questions, give me a shout!
  • JezWynd said:
    Pigeon Fx make a faithful repro.
    http://pigeonfx.com/rangemaster.html
    I do indeed try to make as faithful repro of the Rangemaster as possible  =)
    Are these guys legit? I've heard so little about them.
    I would class myself as legit, I just don't churn pedals out, and tend not to frequent many forums, so alas I low profile in the pedal world!
    I have had a Pigeon Rangemaster - was great, sounded and looked excellent.
    For the basis of the Rangemaster value discussion, I've not really paid much attention to current prices, but I sold my (poor condition) original RM for £800. The chap who bought mine had a few of them and I know he paid over £1500 for his minters.
    Thank you for the kind words, and good to hear you liked the Rangemaster!
    Yeah totally legit. i have had dealings with him before - Brook Morton his name is. He used to sell stuff as kits, normally with everything save the transistors - I built one of his Tone Bender Mk 1 kits and it is superb. Been thinking of building a Rangemaster for a while as I have a few Mullard OC44  but last time I was in touch with him he didn't have any enclosures - and I want one for the coolzzzz!
    Bring back the PCBs and Kits soon! if you still need an enclosure shoot me a email though the website, I have just had a batch in, so can spare one for the coolzzzz!
    I've bought a couple of fuzz kits from him. He's a gentleman.
    Thank you, and you sir are a gentleman too!
