Plane on a conveyor belt
holnrewholnrew Frets: 8207
Image result for pope app screenshot 2
My V key is broken
«13456728
  • HAL9000HAL9000 Frets: 9687
    edited October 2016
    Yes. Because the wheels are free-wheeling rather than driven. It's the jet engines that are doing the work. Jets are reaction engines (burnt fuel/air goes backwards - aircraft goes forwards) so it doesn't matter a jot what the wheels are doing.
    This is dumb. Planes are not cars.
  • holnrewholnrew Frets: 8207
    I was dumb enough to not see it that way for a good few hours :(
    My V key is broken
    Welcome to coding! :)
  • quarkyquarky Frets: 2777
    edited October 2016
    If the conveyer belt turns, there is a trade of energy which must come from the plane. Therefore the plane is expending less energy on forward motion than if it was on a runway right? So the interesting question is, is there any situation in which that energy transfer is enough to stop the plane taking off? I guess "yes" if the plane was heavy enough. But the amount of energy transferred in turning the belt must be quite small compared to the energy required for takeoff..
  • RandallFlaggRandallFlagg Frets: 13944
    Similar question, with a 150mph head wind could a plane take off but appear not to be moving forward?
    Sure, that is just air/ground speed.
  • cacophonycacophony Frets: 385
    is anyone here a member of the f365 forum by any chance?.
    jus' askin'...
  • RavenousRavenous Frets: 1484
    That's more or less what a kite does, so yes.
  • Lift. Think about it.
    My wife asked me to stop singing Wonderwall.
    I said maybe.....
  • GassageGassage Frets: 30928
    edited October 2016
    Ummm, no, needs more wind.  V2 (the speed when a plane becomes airbourne) on a fully laden (MOTW) 747 (pictured) is c. 155 Kn (180mph), depending on flap settings. So ....
    Whatever the weight
    On flap 20, the speed will be lesser but the poz climb rate will be slower.
    On flap 10, the speed needed is greater, and therefore climb rate higher.
    At 20, the stress on the landing gear is lesser and so is the noise.
    So, technically, if the headwind was a mighty 180 mph, the plane would need to be tethered to the ground.
    An unladen 747 would need less. c. 140kts I believe.
    Yes, I'm plane anorak.
  • ennspekennspek Frets: 1626
    I thought this was going to be about the sequel to Snakes on a Plane
  • fretmeisterfretmeister Frets: 24407
    No.
    No airflow over the wings. No Bernoulli effect. No lift.
    0reaction image LOL 0reaction image Wow! 9reaction image Wisdom
  • monquixotemonquixote Frets: 17640
    Mythbusters actually tried this and showed it could take off.
    Here you go- unladen 747-400 taking off into an 60mph headwind unladen!
    600m take off.
    Compare this with Joburg where a fully laden 747 will take 3000m to become airborne.
    No it cannot take off.
    For there to be any net forward motion relative to a stationary observer, the wheels must implicitly be rotating at a faster speed than the conveyer. This is the case regardless of whether power is being delivered through the wheels, or in this case, through the jet engines.
    This more of a thought experiment more than a realistic situation because in reality, it is impossible to create such a conveyer belt that precisely and instantaneously matches the speed of the wheels. However, should such a belt exist, the plane would be kept stationary by the belt through the frictional forces between the belt and the wheels and the wheel bearings, creating a resistive force that matches the thrust delivered by the engine. In reality the wheels would have to be spinning so fast for this to happen that they would probably fail and disintegrate quite quickly as the engine power is increased, putting an end to the experiment, and the plane itself.
  • ChalkyChalky Frets: 6811
    Wheel speed is irrelevant, and the friction of the wheel bearing would be negligible compared to max engine thrust, even if the conveyor belt was moving at 360kt compared to the 747 airspeed of 180kt at take off. So it would take off with ease.
  • SambostarSambostar Frets: 8745
    It can't take off because airspeed is the critical thing to provide lift to the wings.  If air isn't travelling fast enough over them it won't take off.
    Backdoor Children Of The Sock
  • hywelghywelg Frets: 4303
    edited October 2016
    Tosh.
    Wheel and bearing drag will be small in comparison to thrust available from the engines. What limits an aeroplanes ability to take off is relative windspeed over the aerofoil sections.
     Since the conveyor belt has no influence on the windspeed (except in the boundary, probably millimetres) and wheel drag is proportional to conveyor speed the aeroplane will move forwards relative to the ground.
    Since at the start the thrust will exceed the combined drag of the wheels and win,  it will accelerate up to the point where thrust <= air drag + wheel drag. Before this point the forward ground speed will exceed the speed required to generate sufficient lift to take off and wheel drag will cease to influence the equation.
  • rlwrlw Frets: 4708
    Surely in this scenario, there is no air passing over the wings as the plane is actually static, apart from the wheels rotating.  Bit like a rolling road.
