So they can see wind direction and pick a runway
Anyway, that's not the main point of concern here. The critical thing you have to understand is that for there to be any net movement of the plane in the forwards direction (and therefore receive airflow over the wings), the wheels MUST be rotating at a FASTER rate than the conveyor belt is moving in the opposite direction. However, by definition of this thought experiment, this is the one thing that is not possible.
I said maybe.....
Which it is incapable of.
The plane is stationary but potentially at full thrust, which now begs the question could it take off if the windspeed was high enough, and what would that windspeed need to be?
The wheels are irrelevant, they just support the weight of the plane when it's on the ground. The engines generate thrust and the plane moves forward, the wings generate lift against the air and it takes off. The wheels could be turning forwards, backwards or not at all and it makes no difference.
I actually thought this was going to be about something much cooler, the huge conveyors at the Boeing (and presumably Airbus, although I've never seen pics) factories which move the part-finished planes around when they're being assembled. Disappointed...
I quote myself from my previous post:
If you have four clear marbles, but one of them is silver which one is a jelly bean?
The only thing that matters is that the plane is being propelled forwards through the air by the engine thrust. The conveyor could be set to run so the wheels are turning backwards and it would make no difference.
What you don't seem to be understanding is that the wheels are not driven - they freewheel, and provide nothing other than support for the aircraft when it's below flying speed. If they were needed to drive the plane forward, how would it fly once it's off the ground?
Surely if the conveyor was matching the speed of the wheels at all times then the plane would be stationary. Even if the thrust is coming from the jets. The conveyor would effectively be dragging the plane back by the wheels with equal force to the jets. The landing gear would probably be ripped off.
They couldn't build a conveyor that big anyway that is capable for doing 570mph..
How does the plane move forward if the wheels and the ground are moving at the same speed?
