I'm on Firefox, Win10 as well and no problems. Do you have some kind of script blocker (like NoScript) active?
[edit]
I've embedded this track from my SoundCloud page as a test.
https://soundcloud.com/steam-abacus/steamabacus-i-have-a-door-2015
You should be getting an image, a waveform and a play button to play the track directly on this page.
[edit]
Right, I've also embedded the same track from my BandCamp page. Can you see/use the BC widget or is that not working either?
https://steamabacusproductions.bandcamp.com/track/i-have-a-door
You should be seeing a small square image and then a play button and a track duration 'scroll bar'. Again, you should be able to play direct from this page.
I have no blockers active. Java is up to date, I cleared all history and cookies, but soundcloud links from the fretboard still don't work for me in Firefox.
I can login to soundcloud and play tracks there (in Firefox), and the soundcloud link in your post works from Edge, but not Firefox. I can also play the track from your bandcamp page in Firefox.
So everything works - except the soundcloud link from Firefox.
Here is an image of what I see...
I know there were some problems posting the SC playlists in the Riff of the Month challenges just after the forum software was updated.
Maybe @TTony can shed some light on this?
Instagram is Rocknrollismyescape -
FOR SALE - Catalinbread Echorec, Sonic Blue classic player strat and a Digitech bad monkey
