Bridge pickup in neck position?
I have a Fender Japan '62 Reissue Tele that I want to put a mini humbucker in the neck position of. I also have a Seymour Duncan mini humbucker (Les Paul Deluxe style), but it's a bridge position version.
Will it sound shit in the neck position, and be way too loud?
  • You might have some balancing issue in terms of volume but it shouldn't be that huge.
    Personally I would get a set wound of whatever pickups you are after and get them matched.
    You can probably sell the Seymour for £40 which will help you on the way
  • ICBMICBM Frets: 73121
    The problem is likely to be that it will sound too muddy, as well as too loud - bridge pickups are usually wound hotter and more middy than neck ones.
    @ICBM do you know if Gibson did anything different for their mid position HBs in guitars where they had 3 HBs? Always wondered what they did for them...
    Bridgehouse said:
    @ICBM do you know if Gibson did anything different for their mid position HBs in guitars where they had 3 HBs? Always wondered what they did for them…
    No, not normally. In the old days they never had calibrated pickups anyway, they were all the same. As far as I know the Historics are the same too. If there's any difference it will be that the bridge is slightly hotter and the neck and middle are the same - like Strat pickup sets.
  • Oil City Hardman?
    Thanks - always wondered about that.
  • normula1normula1 Frets: 643
    As it happens I did this in Strat over the weekend. The Kinman traditional 3's  AVN56es sounded a bit too brittle, so I swapped the bridge AVN-62 into the neck and dropped a Woodstock AVN69b bridge I had lying around into the bridge position.
    Sounds great now.
