Also it needs to be straight so make sure the holes are right!!
when you say you feel it from raised to lower. Do you mean if I was to use the bar to add shimmer on a chord I would feel it? As you would be going from lower then past the rest position each time
The old Tremsetter can be set up to work very well too - if you ignore the instructions and work out exactly what it does yourself! - but it still can't give that fluid vibrato either side of rest, at the same time as either stopping double-stops going out of tune or holding the bridge if a string breaks, although it can do both those things.
They are also a massive faff to fit and set up the first time, it has to be said.
^ these 2 things.
I've tried all the trem stabilising thingys, the are all crap. After a while you just learn to accept the compromises involved with having a trem on a guitar, that or just block the fucking thing.
There's a Bigsby on my other guitar anyway, and there's no way of blocking that at all.
