perpetual beginners
  • zoglugzoglug Frets: 1
    I first bought a guitar 12 months ago and i have been guilty of being a perpetual beginner! When i first started, all i did was watch youtube video's of songs i liked and tried to learn what was being taught. I quickly realised i was not going to get far doing that. During the 12 months i also had a couple of unexpected breaks in practicing due to 3 house moves which also did not help.
    Recently, i picked up Learn and Master Guitar on the advice of people on another forum. I have found it has been a great resource during the course of the last month but the same issues remain of staying dedicated to following it and making the most use out of the hour or so i get each evening to play. I regularly find myself strumming along to the 4 or 5 songs i managed to learn to play to a fashion.
  • octatonicoctatonic Frets: 33848
    edited August 2013
    octatonic said:
    I'm happy to write up a practice log for people who feel they are getting nowhere.
    Often people don't have an idea of what constitutes effective practice and it can come as quite a surprise when they find out what it actually is.
    You'll need a minimum of one hour 6 days a week- although two hours would get you there quicker.
    But what do you do if you can only grab half an hour now and again?  How do you effectively practice if you can't make a practice schedule, or is it more a matter of maintaining than improving if you can't dedicate time to it?
    I make time.
    Other things get sacrificed.
    If I want to run a marathon I have to make time to go running.
    It is unrealistic to expect progress without doing the work.
    Sorry but that is how it is.
    You will get to a point where you don't need to play 6 days a week to maintain your technique.
    You can't stop completely without it having a definite impact though.
    I had a shoulder operation a few months ago and it took me about a month to get back up to match fitness.
    It sucked.
  • VimFuegoVimFuego Frets: 15634
    I'll be interested in seeing the practice log. I'm following Justin Sanderco's system at the moment, but it'd be interesting to see what else is out there.
  • ClarkyClarky Frets: 3261
    edited August 2013
    Clare - one of the biggest things with learning an instrument is not 'how long' you been playing it, but 'how many' hours you've racked up. way back when I'd only been playing for about 3 years [I think], I had a jam with a pal that had been playing for 10 years. He couldn't believe the difference between us. It seemed back to front because I was quite a bit more proficient. Then we worked out "hours per day" [for me] and "hours per week" [for him]. When we multiplied it all out by the years we'd been playing, it actually turned out that I had more than 4 times his total hours. So in meaningful terms, I'd actually been playing quite a lot longer..
    if you can only play little, at least try to play often..
    also, 30 minutes per day will be better for you than 10 hours on one day per week.. This is because you see the neck more frequently and therefore have less time to forget what you've learned.
    Mine is pretty similar to that- I'll post something sometime today.
    cheers octa, mucho appreciated.
    Here is a practice log from my time at ICMP.
    You can see I break down my time into small chunks.
    This is essential.
    You don't learn *a thing* any quicker by playing it more than 20 mins or so per day.
    Breaking a task down, like Harmonic Minor modes, into 15-20 min blocks and playing them every day is going to be many times more effective than trying to cram it into a one hour block.
    In terms of what YOU (speaking to everyone here) should practice then it really depends on where you are at.
    If you cannot play pentatonic minor, major scale, minor scales, 4 arpeggio types (major 7, minor 7, dominant, min7b5) in a few keys all over the neck then I would start with that.
    Also work on aural & transcription, reading, harmony and theory.
    Once I get a particular thing up to speed I don't play it every day.
    I use a '20 repetitions for 20 days' approach where I play a new thing around 20 times a day for 20 days.
    It goes into long term memory and I refresh it often after that, but not every day.
    I worked up Donna Lee this way- got it to around 200bpm for an exam.
    I can't play it at that speed now but I will never forget the lines and I can get it back to that tempo in a few days.
    My 'fingers know it'.
    Make friends with that idea.
    You can't be on top of everything you've ever played all the time, forever- it doesn't work like that- at least not for me.
    You should never let things lag so that you have to start *from scratch again* though- you do that by never really stopping playing.
    For instance today I've had a lot on and none of it music.
    I'm selling a house and buying a new one- so I've had agents in, photos done etc.
    I've still managed 2 hours of playing today and I'm going to play more now.
    Another thing to consider is all of your 'down time'.
    If I'm standing at a bus stop I'm not just standing there doing nothing- I might be harmonising the major scale in Db, or thinking about how to transpose "Autumn Leaves" into a new key, or reading some sheet music that I've printed out and trying to hear it in my head.
    I'm playing a lot of drums now so I will run through drum rudiments, tapping my hands on my legs.
    I'm just standing there- why wouldn't I do this?
    It is WHAT I DO- I'm a musician- I do music, even when there is no audience.
    A lot of what people need to do is just basic finger independence exercises- they are essential.
    I won't reinvent the wheel so just do what Justin does here: http://www.justinguitar.com/en/TE-001-FingerGym.php
    Mine is a bit different to this but it will do the same job.
    Don't spend ALL of your time doing the finger gym, of course- and once your hands get strong enough you probably won't spend much time doing them- I don't now- at least not often.
    I know this is a bit rambling but I'm trying to explain an approach that works.
    I don't know what you known and what you don't so I don't know what your next step is- only a private lesson or a long PM exchange can inform me of this.
    Also, this is just my way, there are many ways to skin this particular cat but the main skills are persistence and determination.
    Physical skill on an instrument is mostly down to these rather than 'talent'.
    awesome, thx. I may scale it down just a tad, I don't think I know 2 whole hours of guitar, but I get the basic principle.
    When I was at ICMP my practice logs were 4-6 hours long.
    There was a lot of work. ;)
    Now I tend to do 2-3 hours a day of structured playing and a bunch of unstructured playing.
    This is a habit- once you get into it you just keep it going.
  • mike_lmike_l Frets: 5700
    @Octatonic ; That's an immense schedule. I'm going to have to work out something like that for myself, although I can't realistically give more than (on average) 1 1/2 hrs per day (2 hrs on early finish 1 hr on late).
    For a little guidance where would you start.
    I'm thinking
    15mins scales
    15mins chords
    15mins arpeggios
    not really where to go from there.....
    Cheers
    Try this:
    15 mins warm up- finger gym.
    15mins scales - break this down- maybe C major modes in CAGED, in in 3rds, 4ths, 5ths- set metronome to 60% of your maximum speed for most of it, play as fast as you can only for the last 2 mins- again to the metronome.
    15mins chords - Start with Maj7, Min7, Dom7, M7b5 chords in all keys. This is a deep topic. I like the Drop system.
    15mins arpeggios - Maj7, Min7, Dom7, M7b5 arpeggios in all keys- work through 1-2 keys at a time, go around the circle of 5ths- I like to do star with C, then the go in both directions around the circle (So G and F, then D and Bb).
    15 mins aural - Ricci Adams site is great.
    15 mins sight reading- there are loads of books on this.
    15 mins transcription of a solo - pick something that stretches you. Do analysis of the solo, don't just play it, lear to transpose it, play it in different places on the neck, in different octaves.
    15 mins transcription of a rock song, rtm/lead
    15 mins transcription of something acoustic.
    15 mins warm down.
    There is 2 1/2 hours.
    There is more that you could be doing, of course- there is always more.
    Something else to consider- don't consider it failure if you on;y get through 60% of your practice log.
    That is a success.
    Aim high of course but make sure you look at any work as a success.
    @VimFuego said:   ...  I don't think I know 2 whole hours of guitar, but I get the basic principle.
    A bit of practice, a bit of listening, a bit of playing, and a bit of noodling - it's surprising how quickly a couple of hours slips through your fingers  (pun intended)
    Most of all have fun, that's why we picked the guitar up in the first place.
    @clare_bear, what better way to clear the cobwebs and wind down from your MSc stresses than a little time strumming...
    @octatonic thanks for your practice log and advice (wisdom earned me-thinks)
    @octatonic thank you sir, I owe you a pint (or two)
    Very welcome- @ChrisMusic too (Can't figure out multiquote).
    I have a large block folder so I can track what I've done daily/weekly/monthly.
    I may even put it on here weekly so you motley crew can mock me.......
    I'm thinking maybe I should get a drum machine too (I got a couple of metronomes but don't really like them)
    Social pressure is GOOD.
    I talk a lot in my immediate circle about what I am doing and what I plan to do simply because if I talk about doing X project then I have to finish it- mainly because I don't want to say 'oh no, I gave up'.
    Up to you re drum machine vs metronome.
    the best thing about metronomes is they are fast.
    I have a Tama metronome- it is excellent.
    it's the tick/tick or bleep-bleep noise which I find irritating. Besides I can always slightly increase the volume from the Marshall and drown it out..........
    I don't even notice that anymore.
    It is just a pulse- over time you will get good enough that you don't really need it- but you will keep it on as a matter of habit.
  • octatonic;15804" said:
    clare_bear said:
    octatonic said:
    I'm happy to write up a practice log for people who feel they are getting nowhere.Often people don't have an idea of what constitutes effective practice and it can come as quite a surprise when they find out what it actually is.
    I make time.Other things get sacrificed.If I want to run a marathon I have to make time to go running.It is unrealistic to expect progress without doing the work.Sorry but that is how it is.
    You will get to a point where you don't need to play 6 days a week to maintain your technique.You can't stop completely without it having a definite impact though.I had a shoulder operation a few months ago and it took me about a month to get back up to match fitness.It sucked.
    I have an 18 month old son, so it's not possible to sacrifice other things! I'll just have to trickle along.
    This thread has been a great read and great motivation to put my own practice schedule in place. At the moment, i dont think my fingers could take that much so for the forseeable future im going to follow something like this:-
    15 minutes - 10 minute guitar workout (David Mead) Whilst it says 10 minute workout, by the time ive recorded results, reset the timer it usually takes 15 minutes
    15 minutes - Learn and Master Guitar sessions - Currently on session 2, learning the notes on the first 2 strings. Its also good as it is teaching me how to read music too.
    15 minutes chords and chord changes - Using Justin's 1 minute changes exercises
    15 minutes - Song Practice - This will be a combination of songs from the L&M guitar course, but also songs which use the chords i am using during the 1 minute changes
    15 - 30 minutes - Ear training - I signed up to the easy ear training site which has been a fantastic read each and every day.
    Once i get a little better, i will certainly factor in more elements which you mention Octatonic! Again, thank you for sharing your training log.
