WTB a PRS wide thin nut
stonevibestonevibe Frets: 7179
edited September 2017 in Parts £
Has anyone got a spare PRS wide thin nut?
Been looking all over UK dealers and everyone has the regular width one and I need a wide thin version.
  • guitars4youguitars4you Frets: 14468
    I'm sure any PRS dealer should be able to order one for you -just checked on the PRS site and not listed - try this e-mail and ask if he can help mwade@prsguitarseurope.com
  • Cheers fella, will give that a go.
  • JalapenoJalapeno Frets: 6401
    Would think you just want "wide" - thin being the neck thickness, not string spacing
    Feedback
  • Well its wide thin/fat, but it's not the regular width version
    valid point - and yes wide will suffice on the request to PRS - just a thought - let PRS know the age of the guitar, but as far as I know there is no difference in nut width between the former wide/fat and the current pattern/fat - I'm pretty certain that down to the finite MM, they are both the same width
  • These are good .. Graph Tech TUSQ PQ-6643-00 Slotted Nut for PRS SE
  • stonevibestonevibe Frets: 7179
    Yes, I have one or two of those on SE guitars, yet this one is a bit wider and so it doesn't sit properly, leaves a gap on either side of the neck. Only a few mm, but annoying enough to warrant getting a PRS one instead.
    I bought one as on spec, it should fit, yet there is a gap and so I need to try the US nut and hope it is sufficiently wider, so I can file it back to fit.
