A baritone related question. I have a homemade tele style which I'm moving on soon, and am going to look at an alternative option. For whatever reason, most baritones seem to have single coil pickups, and not many come with trems.
Maybe the reason is obvious: humbuckers would be muddy and the trem would be a nightmare on baritones?
I wouldn't be playing metal on a baritone.
I had been thinking of another tele, neck conversion, vibramate bigsby, but fear I could run into problems, especially based on the above previous post.
I like the idea of warmer sounding pickups and not single coils, so in theory, could change pickups in a tele style.
My other options with a trem would be the Gretsch or the Eastwood Sidejack, or more expensive Airline. I wouldn't need to go high end.
I'd probably have to order one of these online, as I'm in Ireland and baritones are rare enough to come across in shops, and Eastwoods would be pretty difficult to find.
Reverend make a shorter scale bari with a Wilkinson trem.
Plenty of PRS options as well currently, but I was never a huge fan of them visually.
I've never played the Danelectro ones, so don't know what they'd be like.
Schecter, I'm not too sure what's available these days.
The Squier Jazzmaster looks really cool, but no trem, which *maybe* I'd get over. I'm a fan of offsets too.
I wouldn't be too inclined to go for a Bass VI either.
If it doesn't work out for you, they also work with normal gauge (10s), tuned D-D
No trem though
I have found that bending sounds shit on low-tuned baritones, so I would assume that's why you cannot find ones with trems, I would leave that alone until you have several hard tail baritones if I were you
I have had a few baritones, so could possibly help advise
btw have you considered buying a Warmoth baritone tele neck and adding it to your current tele?
and also - single coils sound warmer on a baritone than they do on EADGBE
Consider single-coils on basses - they sound warm surely?
It's more the design that's wanting me to move it on.
I had thought of the regular tele with a conversion neck but have read that it's not as simple as it sounds.(bridge position and intonation issues?)
have also considered the latest Jazzmaster baritone...
id be playing slightly overdriven, post rock / shoe gaze in places but mainly slightly dirty
AFAIK the conversion necks are intended to avoid the need for bridge repositioning, but as with any neck swap, they will assume a current size for the neck pocket, and the distance from bridge to neck pocket. Therefore if your tele has any non-standard dimensions, there might be tweaks needed:
http://www.warmoth.com/Guitar/Necks/Warmoth_BaritoneNeck.aspx
they say:
" It is not necessary to modify the body or move the bridge. After installation simply re-intonate your guitar to match the new scale."
Basically you are adding extra frets at the headstock end, all the other frets will be identically positioned to the ones on the original neck.
see the necks in parallel view:
http://www.warmoth.com/Guitar/images/Necks/ConversionNecksCompared.jpg
However it sounds like you want a new guitar body anyway, so perhaps not an ideal solution this time, BUT - if you see a candidate guitar to modify, this can work for you, e.g. a Chinese vibe tele would be considerably improved by a warmoth neck
You can use a longer-scale neck if you want it to feel more like a bass, but it isn't necessary.
Remember that five of the strings are the same as for normal guitar tuning - just moved across one position - and it's only the new low B which is different. (The G becomes an F#, but that's fine with the same string gauge, usually a 17 or 18.)
I used a double-ball-end 65 gauge bass string for the low B, with the large ball end cut off - the small one is the same size as a guitar string.
if buying a new guitar:
same as usual, options are:
- single coils
- HBs
- SSH
- HSH
- Actives
- add piezos
Muddy tone may be a problem, normal guitar pickups start to not work so well the lower the note. hence actives being so popular for baritones.what I would advise is that many bass players use active pickups or EQ, since otherwise it's quite hard to get the tones they want. Both of my basses have active pickups, and 3 out of 4 of my baritones (Whereas only 15% of my standard scale electrics are active). My passive baritone is a tele blacktop (not a very long scale), so only D-D, but I still had to replace the pickups to get a less muddy tone.
Next thing is shape/style/cost
Schecter do the best range, there are quite a few 30 inch models, that can be strung as a baritone or a Bass VI.
Some can be £400 used, which is a good price for the quality.
For huge flexibility, the Steinberger transcale offers it all,but the neck is unusual, so not for everyone
Active electronics are not necessary either - it's true that for a lot of music styles which use baritones or down-tuned instruments, actives give more of the type of tone that's generally wanted so they tend to be used, but you can get pretty much any bass tone from a Fender Precision or Jazz too, and they're not active.
Maybe I should have gone with the neck conversion from day one, but even with a standard body am I always running the risk of the neck not quite fitting ?
A bit too ambitious to consider a vibramate bigsby...
anyone play the Gretsch baritones?
http://www.schecterguitars.com/international/guitars/hellraiser-c-vi-detail
they've reduced it a lot since I bought mine
Clearly looks a bit metal, but I never use an OD on it, I play it like an acoustic guitar really, to do textural stuff, often with bigsky style reverb, or just a wash of delay and verb with some nice phaser patch
I'm guessing the Gretsches are not very high quality given the price, but have not tried them. I'd always go for used stuff if possible, e.g. in this case paying £400-£500 for stuff that is £800-£1k new
as the body, it's just my mate was a novice builder so it never quite took off for me.
I could go this route again and get a warmoth neck as opposed to a blank neck wood and then get the body blank but the money id end up spending in total, i could just get something off the shelf.
that Schecter looks interesting.
In the meantime I got a Jazzmaster (squier) baritone. Thinking of upgrading the nut and pickups. Any suggestions for pickups ?
don't get anything that will get muddy on low notes, or get coil taps or active EQ
