(Cue can-of-worms opening…
Also the Floral Jem I nearly bought a few months ago was a very resonant guitar compared to any RG I've played, including the high-end RG750 I once owned - but Jems also have a bigger neck.
He'd had a Floyd fitted. "My guitar, I can do what I like with it" he told me afterwards. Fair enough...
Was he using the same string gauge, or had he gone down? eg 10s to 9s.
Was the action the same, or lower? A lower action can sound thinner even without audible buzz.
Was the neck shimmed? It does have to be (usually quite a lot) on a Strat unless you recess the Floyd.
Had the pickups been raised enough to compensate for the greater string height over the body?
Even simply taking the neck off the body to rout it and re-fitting it can sometimes change the tone, if it doesn't go back quite as snugly as it had been.
All those things could thin the tone fairly noticeably, without the Floyd itself sounding any different from a standard trem. I'm not saying it definitely doesn't, just that there are other factors involved as well. I've now heard enough guitars with Floyds that sound great to be sure that the Floyd *by itself* is not the tone-killer it's often made out to be.
He was old school so unlikely to have chosen that moment to change strings, but could of course have been advised to.
All ended up with a degree of tone suck.
This summer I got a Feline Guitars with a Schaller Floyd - as resonant as you like and a joy to play
Goes to show a teenage boy with a chisel can do more harm than good!
you need the saddles set high on a Khaler. The big flaw is the bottom half of height adjustment.... it will sound crap if the saddles are in that zone. Surface mount one on a strat style and the saddles will be in that zone and it will always sound crap.
Instagram
But for real tone-suck, the Wilkinson Converter trumped everything - I know some people like them, but it sounded absolutely dreadful to me. It lasted 24 hrs before I took it off again.
