Stumbled across this, this morning, for the upcoming namm
http://www.effectsdatabase.com/model/ibanez/tubescreamer/nu#pictures
certainly interested in hearing more about this one
Nearly 300 euros. The world's not exactly short on tubescreamers.
£239
I see it also has a mix control... so it can presumably sound as awful as a Voodoo Labs Sparkle Drive
http://korgnutube.com/en/
Where's the dedication in the young?
Honestly, it sounds like Tubescreamer.
https://www.andertons.co.uk/maxon-tod-9-true-tube-overdrive-pedal-maxtod?LGWCODE=MAXTOD;56375;6335&gclid=CjwKCAiA-KzSBRAnEiwAkmQ156eHCdHOA3Tkjus-j-j2fWI_h38rd-_i_kZKKmlceXgAEqEYwqis5BoCkmYQAvD_BwE
I guess the new (nu) ibanez will be similar
Other valve-based hybrid pedals like the Mesa V-Twin and Blackstar HT have it the other way round, for a good reason.
Yeah, how often do you push a tubescreamer versus using a tubescreamer to boost a wider frequency range gain stage?
Odd choice.
They should have used a better switch too; those switches are poor and either expensive to replace as a whole unit or fiddly to replace just the switch.
http://jpfamps.com/ibanez-ts-808-tube-screamer-reissue-switch-repair/
I'd still like to try them both though.
