Nice pedal. Quality switches, top notch buffer and a pair of good circuits that are genuinely useful.
Blackstar DUAL?? HT or LT.
Dave.
The D&M Drive's lower gain side is not transparent but TS based, no?
I suggest avoid getting a dual dirt pedal; Instead get two separate pedals you like.
I also have a Boss SD-2 as mentioned above, and it’s awesome too. The crunch channel goes from almost clean to a really nice, smooth overdrive ( which I believe was a unique Boss circuit) and the Lead channel sort of takes over from where the crunch leaves off. It’s not instantaneous in Muff territory as mentioned above, but can get Theresa you increase the gain. It starts off thoug as a nice, thick mid/heavy overdrive.
JM build | Pedalboard plans
Ha ha! Well I guess that side of the OD is a bit nastier!
EDIT: but can get THERE AS you increase the gain
