Using Fractal FX8 with two guitars/amps
imalrightjackimalrightjack Frets: 3821
Hi all,
Forgive my ignorance, but how, if at all, can I use an electric guitar and amp AND an acoustic guitar and amp? A/B switching?
Thanks!
Trading feedback info here
My band, Red For Dissent
  • MoltisantiMoltisanti Frets: 1134
    as there is only 1 Input jack on the FX8 you would need an A/B box to have both guitars connected at once.
    As for the 2 amps that is easy - have one on each output (L/R) and then assign which output is active per preset (with the output L/R mix controls)
  • @Moltisanti Thanks! Now to research A/B boxes...
