This is a journey, and you learn as you go. There’s a lot of expensive FRFR stuff around, and the “favourite” changes all the time. Ditto studio monitors. It’s often best to start with what you’ve already got, because you know how it sounds, and then upgrade as the journey takes you.
I use studio monitors most of the time with mine, and I have a pair of FRFR bigger monitors for going out and about.
FRFR is Full Range Frequency Response. Speakers that give you the full range of frequencies that IRs (or any other audio source) offer. Yamaha DXR10 is what I use, but there are loads of other speakers that you could use.
Switched to a pair of tannoy reveal studio monitors I’ve had for years and never found a use for. Night and day better.
Off the back of that that I got a Yamaha DSR10 speaker on Black Friday.
sounds absolutely amazing. Just huge and wonderful.
Home use only and im in a flat.
Would move on the Tannoys cheap if you’re interested.
But to answer you definitely studio monitors or small PA worked best for me
if you’re at home mostly, get yourself some nice monitors instead. I have Genelec 8020s and they’re used a lot more than the Yam’s.
