Anyone used the Chipex Stone Chips Touch-up Paint System?
rocktronrocktron Frets: 806
edited February 2018 in Off Topic
I have a small stone chip on the bonnet of my car which, if left untreated, would get down to the bare metal. I would like to avoid having to respray the entire bonnet.
 Anyone used the Chipex Stone Chips Touch-up Paint System to cover up stone chips on their car?
My concern is whether the solutions used would affect the clear coat and paint of the area surrounding the stone-chip.
Watch the Chipex video here:- https://www.chipex.co.uk/touch-up-paint/ford/
A user demonstrating how he covered up a stone chip on his car:-
  • Your video link isn't working.
  • simonksimonk Frets: 1467
    Save your money and just buy the correct touch up stick from a decent motor factors (and that does not include Halfrauds...)
    Forget using the the supplied blobby applicator and get hold of a small artists paintbrush... I use a ‘2mm Flat’ (you can give the brush a ‘haircut’ to make it slightly more pointy if you wish). Degrease the area and touch up the chip.
  • chillidoggychillidoggy Frets: 17137
    Yes, I have some for the Lotus. No better than a normal touch-up paint stick thing.
  • SassafrasSassafras Frets: 30320
    Not cheap, is it?
  • ToneControlToneControl Frets: 12096
    can this be used to un-relic guitars?
  • DominicDominic Frets: 16293
    Agree............none of them are great.........I bought the "Hearing -Aid Beige " for the Allegro and the Velour cleaner for the upholstery where the cat had an accident.............still looks like a Paedo's car
  • 57Deluxe57Deluxe Frets: 7352
    don't try this on your guitars though...
    https://medias.audiofanzine.com/images/normal/duesenberg-starplayer-tv-352968.jpg
    custom 'stone chip' fin
    <Vintage BOSS Upgrades>
  • I have used it on a metallic finish car. It worked well on larger chips but wasn't any use on small chips as the post-application rubbing down phase tended to remove the new paint.
