Line 6 DL-4
13»
  • Three officially, but you can kinda squeeze six out of it.
    The "expression pedal" function is a bit of a scam- it doesn't run through every value between your set minimum and maximum, it flips from one to the other at a specified point in the pedal's sweep. So, since you can have the expression pedal alter every parameter except the delay mode, you could assign two different sounds to each footswitch as long as you keep the same delay mode.
    This is how the "double preset mod" works- just a switch that puts a 10k resistor in series with the expression pedal contacts to fool the pedal in to thinking that the pedal is at minimum or maximum. You could house it in an external box if you didn't want to hack your pedal about.
    Image result for line 6 dl4 preset mod
  • ICBMICBM Frets: 72927
    edited February 2018
    [DL4mod]
    That's an incredibly bad way to wire that scheme - it maximises the potential unreliability by using as many contacts as possible.
    You could achieve exactly the same function by connecting the 10K resistor directly across the switch and using both poles in parallel to bypass it.
  • ICBM said:
    [DL4mod]
    Not my diagram, but worth knowing.
