Don't know Dan, will search up a schemo and see if I can work out the pot problem. You often find redundant tracks/drillings on PCBs. Might be that the same board was/is used for another amp? (the Artist is effectively an HT-40 chassis) Might be the designer had Great Plans but the bean counters held him back!
You have to make economies where you can in this game. All the S1 rear PCBs are AFAIK identical fro example.
Oh! What is the service query? Did not pick it up.
Dave.
Of course.
I was just tongue in cheek stating I'm using less than 100 watts too.
