Let's get this off to a good start!
  • monquixotemonquixote Frets: 17670
    surfguy13 said:
    Don't seem to be able to load a photo as I normally would from Image Shack?  Used the 'embed an image'  (for forums) link, which is what I normally use, but when I post it the photo doesn't load, only the link.  Hmmmmm........?
    You don't need to use BBCode ([IMG]) just the link and the site does the magic.
  • WezVWezV Frets: 16791
    edited August 2013
    here is my bass:
    I wanted a P-bass to put a BKP in, but decided to go with a new shape inspired by a teisco spectrum i used to own.  made it a bit curvier at the waist and extended the top horn.  Also its a 35" scale which i find really comfortable and snappy
    will probably refinish it at some point.  I like the aged copper  but would like to maybe do it in a blue like the teisco
  • surfguy13surfguy13 Frets: 133
    edited August 2013
    Hi guys
    Thanks for the tips but no, tried all the options including just cutting and pasting the link but it doesn't want to know, just pastes the link in the post when you hit 'save comment'?
    click in the picture icon  which is to the right of the undo/redo buttons above the text box.   paste the link in there
    edited August 2013
    Thanks WezV.....here goes!
    seems like you have pasted the link to this thread in the box
    I did it the way you suggested......I left clicked on the picture icon (couldn't right click as none of the options were appropriate) and it brought up a box for a link.  I pasted the link into that box and........?
    When it came up as it has I went back into the post and edited it and tried doing it the same way but with different Image Shack links, there are a number available.  Each one I tried either resulted in the link embedding in the post or the word 'image'.  I'm at a bit of a loss.......?
    Right, I'll give this a try yet again!!  :)
    http://imageshack.us/photo/my-images/24/dsbq.jpg/
    edited August 2013
    Delete this, I was just trying something
    You want the direct link and just paste it in
  • ddloopingddlooping Frets: 325
    edited August 2013
      Aha.....brilliant!!  You beat me to it!  :)  Thanks again for the help.
    • BassBunnyBassBunny Frets: 1
      edited August 2013
      Here's one of mine.
    • VimFuegoVimFuego Frets: 15630
      no way I can compete with some of the fine basses on display here, but here's my humble offering. Aria something or other, picked up from a house clearance auction for £20.
      edited August 2013
      A picture of my actual Fender Jazz as posted on the Machinehead Hitchin website. Sadly the shop is no more.
    • ICBMICBM Frets: 72663
      [Aria]
      Steal! The bass player in my old band has something similar that she's had since new some time in the 90s, it's a CTB or something like that - hers is green :). It has a plywood body, generic pickups, active tone circuit that she never uses... and it sounds great. Really no reason why it should, but it's just fine.
      You can't go wrong with that .. looks seriously cool and beaten up ..
      I'm not sure about the body, it could be solid judging by the wood exposed by the "nick", but then the paint is so thick, it don't really matter what's under there. The electrics are not the best quality, but it makes a noise. I did buy it with the intention of stripping the paint and giving it some new electrics and pups. If I ever get myself a "Proper" bass I may still do that one day.
    • ESchap said:
      My old warhorse from 1972/73.  Had all its original and useless pickup split / series / parallel circuits removed; extremely versatile bass with just two volume a master tone and a three-way switch.  Hipshot bridge makes a huge difference to tone and sustain versus the original Gibson 3 point.  Remarkably light for all maple at 8lb 3oz.
      Lovely, lovely, lovely. Top work :)
